Will a tranny for a Y8 engine fit on a Z6 engine?
I have a 94 Civic EX and I am looking for a used transmission. I found one but it is out of a 96-00 EX with a D16Y8 engine. I called the guy at Honda and he said that the tranny won't fit on my 94 EX because the rear mount has a different size bolt. Does anyone know if there is any truth to this or what I would have to do to make it fit?
RE: Will a tranny for a Y8 engine fit on a Z6 engine?
all d-series trannys are interchangeable, all b-series trannys are interchangeable, h-series, k-series, f-series, etc...
someone correct me if im wrong but thats what ive been told by a few different sources.
The Honda guys said that the tranny will bolt on to the engine but there will be a problem with the rear bracket. He said the 96-00 bracket is smaller and uses a different size bolt than the 92-95.
ladyM08
04-14-2008 01:08 PM
davster
09-28-2007 10:23 AM
94, civic, civix, differential, fit, honda, mounts, series, trannsmission, tranny, transmission, work, y8, y8trannyandz6engine, z6
