What clutch/flywheel?
Old 01-03-2006, 10:24 AM
skytanker2003's Avatar
Default What clutch/flywheel?
Got a '96 HX D16Y5. Wondering if anybody as suggestions on which company to go with or whatever.
Old 01-03-2006, 02:01 PM
Default RE: What clutch/flywheel?
I've heard nothing but good things about Exedy and Cluthmasters
this is your DD right?
Old 01-03-2006, 02:19 PM
Correct, it's my DD. I figured I'd rock the D for a while, and leisurely save up for my K. I'll focus on putting together a nice TC'd D for now and see what I can make of the SSAUTO kit. And I too was looking at Exedi and Clutchmasters...Is there much of a difference between Stage 1-2-3-4? I was thinking a stage 1 or 2 since mine's not going to be a demon at the strip and also thinkin an Exedy flywheel. Or maybe just get a newer D tranny and put this stuff in the new tranny. So many ideas!!!
Old 01-03-2006, 04:05 PM
finalimpact's Avatar
i had an exedy stg 1 along with a fidanza flywheel on my old ls swapped crx. very nice combo imo. although the engagment was a little touchy with the stg1.
Old 01-03-2006, 05:30 PM
Im running an ACT stage one clutch and racelite flywheel in my single cam civic and have no complaints. I had a Centerforce dual friction clutch in my crx previously. No probs either way.
Old 01-03-2006, 09:09 PM
My buddy Bart has an ACT stage 1 clutch, and loves it.
Old 01-04-2006, 08:15 AM
For daily driving purposes, I would say go with a stage one, two at the VERY VERY MOST.
Old 01-04-2006, 08:25 AM
How bout this ACT clutch and this Fidanza Flywheel? And Forty, what about a TC'd DD? And I don't know how to tell Stage 1 from 2 ect. What Stage is this ACT?
Old 01-04-2006, 08:31 AM
sacicons's Avatar
personally, i dont like the aluminum flywheels, because you have to bolt the friction surface to it, and that leaves you with two metals with different thermal expansion rates bolted together, and a bunch of screws that could loosen and cause you all sorts of grief. thats why i chose the Exedy 1 piece chrome-moly flywheel. that, along with an Exedy stage1 has worked out perfectly for me.
Old 01-04-2006, 08:33 AM
I'm assuming that since your turbo's turned your D into such a "powerhouse" that the stage 1 etc. was more than good enough to keep up?
Quick Reply: What clutch/flywheel?
