What are the best clutch and fly wheel?
Old 02-26-2006, 07:00 PM
95 Civic B16A's Avatar
Default What are the best clutch and fly wheel?
what are the best clutch and fly wheel for a B-series trans? I believe that is all you can do to a trans.
Old 02-26-2006, 07:30 PM
Default RE: What are the best clutch and fly wheel?
Any one have any ideas?
Old 02-26-2006, 07:46 PM
Pete's Avatar
You can get an LSD Too.
Old 02-26-2006, 08:02 PM
ya i'm thinking about getting this
High performance manual transmision Type 2 http://www.gearspeedinc.com/products.htm
Old 02-26-2006, 08:05 PM
so what clutches and flywheels are best. who make the best?
Old 02-28-2006, 01:19 PM
get an exedy or act clutch. fidenza flywheels are good. Don't get anything over stage 1 unless your going to get your tranny built. Lsd is a good upgrade you can get in stock trannys from japan, but you you want to add it to yours it's going to cost you.
Old 02-28-2006, 02:45 PM
this is the tranny i am going to get
Old 02-28-2006, 04:24 PM
That's a bad *** tranny! You'll only need that if you intend to have a very high output engine.
Old 02-28-2006, 04:29 PM
ef4life's Avatar
i don't recommend a aluminum flywheel with a bolt on friction surface because they are known to come apart. i recommend an all 1 piece steel flywheel like an act, or kaiten. act act or exedy clutches are good
Old 02-28-2006, 05:58 PM
wich clutch do you like best? I can't choose between act or exedy.
Quick Reply: What are the best clutch and fly wheel?
