transmission oil replacement
Old 09-03-2005 | 12:28 AM
1992civicsi's Avatar
Default transmission oil replacement
G'day, i've recently bought a civic si 1992 with d16a8 engine. Its done 310000km and is due for transmission oil replacement. I just want to know where the spot is to put the oil in?
Old 09-03-2005 | 10:56 AM
glada96EX's Avatar
Default RE: transmission oil replacement
Look at the trans through the engine bay. Closes't to the firewall on the side of the trans is the fill plug.
***Heres a pic, it's sort of fuzzy but it should give you a good idea. Its the plug in the center of the photo.***
Your drain plug is up front on the bottom more. Just look under the front fender and youll see a plug made to fit with a ratchet. Hope this helps.
oilltd
06-10-2008 05:06 PM
droopy128
03-01-2008 12:11 AM
Dancivic
10-24-2006 03:27 PM
Dancivic
10-24-2006 07:25 AM
