tranny help plz
Old 12-10-2008 | 07:35 AM
WipLash's Avatar
Default tranny help plz
just a quick question, what are some of the symptoms if the input shaft bearing or the pilot bearing need replacing. i think i got to do those on my car, when it was idle i would hear that grinding sound once in a while then about 3 days ago my car died. has a little bit of trouble going into gear, does not drive unless it is in neutral then will get up to like 5mph and thats it. kinda seems like its almost stuck in gear.starts to barely move like you can drive slow around a parking lot but thats about it, but don't seem like it any power like its stuck in gear also i put it in any gear and start letting off clutch and acts like it wants to go but doesn't and wants to stall only in neutral it will move a bit. tks for any help oh btw its a 93 civic ex with a 95 b18b1 motor swap stage 2 clutch
Old 12-11-2008 | 12:24 AM
How the hell do you drive in neutral?
It's really hard to understand what you're asking. Please use at least somewhat complete sentences and it will make it easier for us to answer your question.
Old 12-12-2008 | 08:16 AM
iheartJDM's Avatar
any way your shift linkage is disconnected and your trans is still in gear?
Old 12-12-2008 | 09:26 PM
WipLash's Avatar
nope, i checked that
ef9101
08-22-2009 07:31 PM
PaTKRider
06-26-2008 10:02 PM
civicblend97
02-16-2008 09:27 AM
that_guy5
02-09-2007 09:09 AM
darknightmr2
03-14-2006 07:44 PM
