shorted clutch movement..
http://www.omnipowerusa.com/Products...r_Cylinder.asp
i was thinking a lil while back if it were possible to make somekinda contraption to shorten the clutch movement for quciker shifts and seems like Omni-Power did it. my friend told me its about $200 and u have to bleed the brake lines and prolly have to buy new clutch lines but still seems like a great addition for hardcore drag racers...
RE: shorted clutch movement..
Well.. It's a good idea.. but you will not have to do anything with the brake lines.. they dont even conect with the clutch second.. if your not leaking anything i would not replace them unless you have the money.. last thing.. i would spend the money on other things to make the car faster before you worry about shifting faster.. you can shift as fast as you want but with no power to the ground you go nowhere real fast
WellFedHobo
08-09-2008 06:24 PM
m015094
02-13-2007 10:49 PM
sparklefrog
07-23-2006 08:39 PM
