Popping out of gear
Old 04-23-2006 | 12:11 AM
sacicons's Avatar
Default RE: Popping out of gear
ORIGINAL: riceburner700
if its poping out of gear than the only thing it could be is bent shift forks, that is the only thing that will make it pop out of gear.... when you "grind your gears" you arnt actualy grind any gears, you are smashing the blocking plate and dog teeth on the gear( not the actual teeth).
I had one that wouldnt stay in any of the gears at the top of the shift pattern. 1st, 3rd, and 5th. it wasnt the shift forks, it was the bearings on the input shaft. they were so worn that the whole shaft was moving enough to keep it from fully engaging the gears. that was fun.
oh, and if your clutch is getting old, replace it, that might help, but youll probably be needing a transmission in the next year or so.
Old 04-25-2006 | 04:04 PM
Ei8's Avatar
Ei8
I got a new transmission 2 years ago. The popping just started occuring a few months ago. But only in 3rd gear. Only happens 1 out of 100 times thou. So, it's not constant...but when it does happen its annoying.
I havent tried draining the Manual Transmission Fluid yet...I'll try that and see what happens....
thanx for all the info...
Capnx
10-30-2010 09:03 AM
05BlueEX
12-11-2009 07:08 PM
05BlueEX
12-08-2009 06:37 PM
pfairchild
11-25-2006 11:22 AM
ncpot
08-24-2006 07:53 PM
Quick Reply: Popping out of gear
