Performance Clutch Install Problems D16Z6
Old 10-12-2011 | 04:12 PM
JSB4DRPAUL's Avatar
Default Performance Clutch Install Problems D16Z6
I just had an F1 Stage 1 racing clutch installed in my 94 Civic DX (D16Z6) after my OEM clutch bit the dust. The mechanic had no problems installing it as far as everything fitting but the clutch is not being pushed in far enough to disengage it from the engine in order to put it into gear. What's up with that?
Old 10-12-2011 | 05:28 PM
Either the clutch master cylinder is done, or the pedal needs to be re-adjusted.
Old 10-14-2011 | 12:18 AM
mpklkj's Avatar
i had the same problem with the f1 racing clutch mine was stage 1. there so gay and **** up like that. is your clutch sensor plugged in? beneth the dash?
Old 10-14-2011 | 10:47 AM
JSB4DRPAUL's Avatar
I've got a mechanic working on it but I'll let him know about your comments. I'll also let you know what the problem was once it's fixed FYI. Hopefully they'll be finished with it today.
runswit2guns
05-10-2012 10:06 AM
Flipz
04-12-2011 03:00 PM
mosagalzeta
04-14-2008 09:12 PM
01civicexblue
07-21-2007 06:05 PM
SlowCoder
16
12-01-2004 12:56 PM
