need help sumthins broken lol
Old 10-26-2007 | 11:38 AM
rcalimquim's Avatar
Default need help sumthins broken lol
alright i got a big problem. my 97 civic ex 5-speed, the cars like stuck in neutral, i think the clutch is done. the car starts fine and runs good, the trannys gears are still in tact i can shift into them with out pushing the clutch and it doesnt screech or grind is that a broken clutch?
Old 10-26-2007 | 04:19 PM
StifflersMom's Avatar
Cat Fuсker
Default RE: need help sumthins broken lol
sounds like it....what's the milage?
Old 10-26-2007 | 05:41 PM
foress_89's Avatar
My car did the same, the clutch was gone.
Old 10-28-2007 | 03:18 AM
Cyphen's Avatar
when you floor it does it sound like its not grabing the gear?
Old 10-30-2007 | 05:14 PM
hydroheven's Avatar
yo i think i have the same problem. i replaced the axles cuz they broke too, and it runs fine, but doesnt move, when i let off the clutch in neutral i can hear a slow quiet grinding noise. no gear works, but when i engage the clutch, it seems to be smooth when i shift thru the non-working gears. am i crazy or is the tranny just gone?
Old 10-30-2007 | 05:42 PM
rcalimquim's Avatar
when i push the gas it sounds normal, no grinding or nothing ,but when i release it i can hear a lil ping or chime like a penny going down a well.i can shift the gears with no grinding and the gears seem to be good.
Old 10-30-2007 | 06:44 PM
riceburner700's Avatar
you probably broke your pressure plate or cracked your clutch disk, might want to have it checked out by a mechanic
Old 10-30-2007 | 07:05 PM
mxs's Avatar
mxs
sounds kinda like my CRX, it had a broken clutch spring
Old 11-20-2007 | 11:55 AM
slottieskim's Avatar
same problem. happend this mourning once i drove out onto a busy street at lunch time. i was about to shift to second, it popped out of gear and luckly coasted into a parking lot. i tried shifting with and without the clutch and it felt exactly the same, it was as if the clutch was always engaged. I heard a few pings when revd. someone told me about axels popping out after a swap, i have a b18c1 with an s80 and check engine light is on. i reached under and was able to turn the axels by hand, what does that mean?
Old 11-26-2007 | 11:51 AM
thanks guys for helping me out. oh and by the way, its just the axels.
gearheadmike
07-01-2010 11:35 AM
Phx Civic
03-19-2010 03:06 AM
mombo
09-04-2006 10:11 PM
Mr Mobsta Man
07-08-2006 01:55 AM
AnakinKenobe
03-06-2005 11:13 PM
Quick Reply: need help sumthins broken lol
