Manual transmision fluid
Old 01-06-2005, 10:20 PM
sacicons's Avatar
Default RE: Manual transmision fluid
the fill plug is a pain to get to. its a 17mm bolt on the passenger side, right above the driveline.
and the honda manual transmission fluid is "best" but they make it sound more important so that they make more money.
Old 01-18-2005, 05:37 PM
Woohhoo changed mine today and found some metal shavings (ouch!) anyone know of a good rebuild kit thats not quite expensive?
Old 01-18-2005, 11:30 PM
sacicons's Avatar
some metal shavings are "normal" in a manual tranny. as long as its not excessive. and dont bother rebuilding ti, just get another one off of Ebay.
Old 01-19-2005, 02:14 AM
Kappa22's Avatar
Actually, I would say don't even try reubuilding it at all. For the amount of work it takes and the number of chances you have to screw things up (especially if you haven't done it a few times before), you'd be better off getting a low-mileage used one from Japan. Less than $200, usually.
Old 01-19-2005, 09:09 AM
yea i would definatly go with getting a different one before rebuilding....i know at the junk yards in my area...for a tranny with a 30 day warrenty its 98 bucks...without the warrenty...64
Old 01-19-2005, 03:02 PM
Kappa22's Avatar
But the Japanese ones are generally the better condition...
Old 01-21-2005, 09:19 AM
thanks and about that tranny oil hmmmm
Old 01-21-2005, 01:02 PM
Kappa22's Avatar
10w-40 motor oil...
xshortyx18
12-09-2011 05:47 AM
StarvingStudent
04-15-2007 03:04 PM
justinwebb
01-27-2007 10:15 AM
POLYTHING
09-15-2006 02:25 PM
rlorenzen
07-24-2006 05:54 AM
Quick Reply: Manual transmision fluid
