How many RPMs @ 60 MPH?
Old 10-01-2007 | 01:13 PM
asdfbrendan's Avatar
Default How many RPMs @ 60 MPH?
I was just wondering how many RPMs my Civic should be running at while doing 60 mph. I've got a 98 Civic HX (D16Y5) w/ a manual transmission. (I recently converted to a M/T, and just wanted to make sure everything was working properly.)
Old 10-01-2007 | 02:10 PM
mxs's Avatar
mxs
Default RE: How many RPMs @ 60 MPH?
And what trans did you use??
Old 10-01-2007 | 02:14 PM
A000. Which I believe is the transmission NOT found in the EX/Si.
Old 10-01-2007 | 02:24 PM
mxs's Avatar
mxs
Ok, here's what I found
http://www.knology.net/~jediklc/gearratiosdseries.htm
P20-A000 = DX,CX,VX trannys
You can use this to figure it out
http://www.fatboyraceworks.com/gears/
Old 10-02-2007 | 05:50 PM
foress_89's Avatar
well without using this.. I can tell you that most 4 cylinders I've drove ran at about 3000RPM at 60 Mph..
Old 10-04-2007 | 04:19 AM
plethoric33's Avatar
I run 3000 at 70mph with a stock setup on a 98 LX. So just a little less should be about right for your question.
Old 10-04-2007 | 07:15 AM
Marty's Avatar
ORIGINAL: mxs
It does not matter, all d series manual trandmissions through 00 have the same 1st and 5th gear ratio which is .702
Old 10-04-2007 | 07:42 AM
mxs's Avatar
mxs
ORIGINAL: Marty
ORIGINAL: mxs
but the final drive is different.
92-95 Civic DX LX: 4.058 final drive = 60 mph @ 2500 rpm in 5th
92-95 Civic Si/ EX: 4.250 final drive = 60 mph @ 2600 rpm in 5th
92-95 Civic CX/VX: 3.250 final drive = 60 mph @ 2000 rpm in 5th
Old 10-04-2007 | 07:53 AM
What's the equation for converting final drive or gear ratios into RPMs?
Old 10-04-2007 | 07:55 AM
mxs's Avatar
mxs
ORIGINAL: mxs
