Flashing D4 light and shifting not smooth
Old 02-17-2010, 07:20 AM
norbster86's Avatar
Is that pic an open connector you found when opening the hood? Or did you take that connector that was dangling underneath your car and pull it up top side?
Old 02-17-2010, 08:49 AM
The main shaft speed sensor and linear solenoid both have a red wire and a white wire:
Old 02-17-2010, 08:56 AM
Originally Posted by myaman
The code is 1 long flash followed by 16 small flashes, that means 16.
I don't know what the 1 long flash code is?
Old 02-17-2010, 08:59 AM
Originally Posted by norbster86
^^That's what the linear/control/shift solenoid looks like^^
It should plug in right behind your hand in that picture actually. Look around, you're very close.
If plugging it in doesn't fix it, and the trouble shooting steps on pg 505 reveal a dead solenoid, rockauto.com has one for 132.89.
Definitely do the trouble shooting steps and let us know what happens.
This picture above is the shift solenoid A and B, not the linear solenoid.
Here is the linear solenoid assembly:
Old 02-17-2010, 09:03 AM
Code 16: Fuel injectors What book are you looking at?
I don't think you have the right code.
You are talking about the OBDI CEL code 16. The OP is talking about OBDII D4 transmission code 16, which is indeed for the transmission linear solenoid.
Old 02-17-2010, 09:05 AM
Thanks Norbster, but this solenoid has blue and green color wires. And my connector has white and red wires, I am thinking that these 2 might be different solenoids.
If you have a disconnected 2P connector with a Red wire and a white wire, then the linear solenoid is probably unplugged.
Old 02-17-2010, 09:47 AM
norbster86's Avatar
I just can't see how a code 16 wouldn't throw a CEL and cause your rough shifting is all.
Edit: looking at the wrong code 16... service manual does say Linear Solenoid. On page 505 "Honda Civic (96-98) service manual", go through the steps for testing the solenoid. Starting with measuring the resistance at the connector.
That was staring me in the face. Looking at the shift solenoid not the linear (There's a freaking arrow pointing to it!) Should have seen that
Do I still get points for trying?
It really seems like the connector is unplugged.
Old 02-17-2010, 09:58 AM
You still get a big E for effort.
Old 02-17-2010, 10:22 AM
norbster86's Avatar
Thanks Ron. I'm a trouble shooter (not just cars, I'm an IT Tech)... absolutely love. I love it when my car breaks so I can fix it.
Just hate it when the wrong rabbit holes are traveled down cuz I missed a detail.
Old 02-17-2010, 10:33 AM
myaman's Avatar
Thanks Guys for the helpful responses.
I will try to find Linear solenoid, I was able to locate shift solenoid by opening the hood, the one in the pic near the top right corner is the shift solenoid (I believe so). As per the pics posted by RonJ linear solenoid should be near shift solenoid.
If its so high from the ground then probably I didn't broke it by backing it off the curb edge.
Quick Reply: Flashing D4 light and shifting not smooth
