d16y7 'transmission' leak
I have a auto transmission with the d16y7 motor. There is a line going into the transmission that is leaking. I'm pretty sure that its a radiator line, but i'd like someone more experienced to reassure me. The line is connected to the transmission right next to the speed sensor. Is that a coolant line? And would i just need to change a crush ring, tighten the bolt? What would be other repair options? Thank you for your help.
RE: d16y7 'transmission' leak
yes, it goes to the radiator.
put a new hose clamp on it, the kind with the screw that you tighten to clamp the hose, the stock ones are pretty weak. that's probably why it's leaking.
Dwack1992
04-08-2013 04:05 PM
Aaron A Archer
12-04-2011 05:30 AM
Aaron A Archer
12-03-2011 03:38 PM
