Civic Type R EP3 gearbox noise
So the noise I’ve been hearing. It’s when you are doing engine braking mainly, or if you are coasting along doing 30 in 3rd. Each time you let the momentum of the car turn the engine the noise get audible. It sounds a bit like a grinding noise, possibly bearings. If you just gently touch the accelerator it almost disappears..I heard that it is possible that the bearings are making noise(Input shaft bearings)if someone had a similar problem?Car is Civic Type R Ep3 2004 95.000km..6 speed..
Yes,but that sound is not that strong in idle,only vhen i slowing down in gears(1,2,3)Engine braking the sound is strong..If you just gently touch the accelerator it almost disappears..sory for my bad English..
stalin11
04-27-2011 12:53 PM
phil540uk
11-01-2007 02:39 PM
unklbens
08-11-2005 05:56 PM
