Check Engine codes say tranny issue
Old 01-22-2007 | 01:16 PM
Methu969's Avatar
Default Check Engine codes say tranny issue
My daughters 97 civic had the check engine light come on and she says at 3000 RPM it started acting weak.
I drove it and had no isses, other than the light being on, took it to Autozone and here are the codes, anyone see this before??
P0700 - The PCM has received a signal to turn on the "Malfunction indicator lamp" from the transmission contril system.
P0715 - The PCM has determined that a malfunctionexists in the input circuit for turbine speed sensor.
mudhenFUF
01-16-2023 08:43 PM
that_guy5
03-16-2007 07:18 PM
Methu969
01-22-2007 01:13 PM
mobbology
11-29-2006 05:37 PM
emericanidol
01-19-2006 12:47 PM
Quick Reply: Check Engine codes say tranny issue
