cable to hydro help
RE: cable to hydro help
LSD stands for limited slip differential. Several companies make them for honda transmissions. It's ultimate purpose is to retain traction under high horsepower loads. They help give you a better hook up off the line. At least that is my understanding.
buy a hydro tranny...........you cant convert unless you want to fab up a braket for the slave cylinder. and cable trans are pos. pre 92 have weak diff pins which tend to wear out, explode and take the case with it.
