B18C EK Swapped Shift Linkage Question
Old 08-22-2009 | 12:08 PM
EJ8_Man's Avatar
Default B18C EK Swapped Shift Linkage Question
Hi,
I've been told that I need 99-00 Si Shift Linkage for my B18C ITR swap, but I've read that the shift linkage out of the DC2 ITR will work. So which is it do I need to buy the 99-00 Civic Si Linkage or can I bolt in the ITR linkage?
My car is a 99 Civic EX coupe the donor B18C is out of a JDM 1999 DC2
Thanks
Old 08-22-2009 | 11:27 PM
EJ8_Man's Avatar
Bump.
Does anyone know the answer to this?
Old 08-22-2009 | 11:33 PM
i do know when you swap a dohc into a sohc car you do gotta change the linkages
http://www.jspecautosports.com/page.aspx?page_id=17
Old 08-23-2009 | 08:30 AM
plethoric33's Avatar
Pretty sure either will work. I remember reading something about it on Honda-Tech. I have an LS linkage for my LS swap in my EK, so I dont see why you couldnt just use the ITR if you have one.
Old 08-23-2009 | 08:44 PM
EJ8_Man's Avatar
Thanks for the replies. If your LS linkage works then the ITR linkage should work too I'd think.
Jake Dillon
11-15-2012 02:50 PM
PREKGSR
06-08-2008 11:55 AM
b16avtec
05-25-2007 07:13 AM
95h22civic
05-23-2007 09:20 PM
twon
09-26-2005 08:55 AM
Quick Reply: B18C EK Swapped Shift Linkage Question
