96-00 Upper tranny mount
RE: 96-00 Upper tranny mount
well its from a 94 manual but i think the trannys are the same. i dont see them changing the mounts much..
tho not sure which one your talking about UPPER.... cause they are all preaty level
thiers 3 mounting points... the rear, the side and the front side..
and heres the side and side front mounts on the tranny
No I think that pic shows the bolts that mount the tranny to the block. Maybe I should have been more specific. I need a pic of the motor mount that mounts the tranny to the frame. Thanks again RonJ
Addiction- The mounts from the 92-95 vs 96-00 are bass ackwards haha. 96-00 has 2 removable mounts where the 92-95 only have one and its just a pinch different. I was needing a pic of a 96-00 manual mount to what it looks like compared to the mount that I have, which is an auto mount.
I you think that diagrams in the 96-00 Civic service manual might help, go here:
http://hondatech.info/downloads/Auto/Manuals/Civic/
I just need someone that hasa pic on hand or someone that can run out and take a quick pic of there manual tranny mount so that I can see how it compares to mine. I don't want to buy something if its just like the one that I already have. Thanks
I have a 97 Civic DX 5-speed. I was standing by the driver's side headlight when I shot the first picture. The red arrows point to two bolts attached to a mount extending to the frame on the passenger-side engine compartment (not visible in picture).
I was standing by the passenger's side front fender when I shot the second picture. The red arrow points to a bolt attached to a mount extending to the frame on the lower firewall (not visible in picture).
These were the only transmission mounts visible from the top side of the engine.
[IMG]local://upfiles/25538/75FEBF9CCFA74A59928DC05160578E65.jpg[/IMG]
[IMG]local://upfiles/25538/8CE9F8CD80544AD38EA9FABA67D7B772.jpg[/IMG]
Thank you very much RonJ! The mount I was speaking of is actually right under your stock intake box. I messed around with it alittle longer before I had to go to my under ground mining classes and got everything to work somewhat. It's not perfect, but it should work. Thanks again for always being so helpful when I run into troubles!
Jeremy102579
03-12-2005 03:07 PM
