95 Civic - 5spd to auto swap?
Old 10-03-2010 | 02:06 PM
TxFireman1972's Avatar
Default 95 Civic - 5spd to auto swap?
I have found lots of write ups on auto to 5spd, but what about the other way around? I have a 95 Civic that I'm considering swapping over to auto for my daughter.
The main thing I'm interested in is:
what all parts would I need?
Anybody have a writeup on it?
Old 10-03-2010 | 03:10 PM
stoochy's Avatar
It would be easier and cheaper to teach your daughter to drive standard IMO.
Old 10-03-2010 | 03:13 PM
ok...so back to the question at hand...what all is involved in the swap?
Old 10-03-2010 | 07:06 PM
Superfly's Avatar
I did the opposite swap, because Honda autos aren't very good, and I absolutely love driving a manual. But here's some things you might encounter:
You might have a problem with a transmission mount. I did on mine. The Auto trans mount was an inch to the left of where the manual trans mount. We opted to weld it in....but this was on my 1999.
You'll probably have to cut out and weld/bolt down the sheet of metal from an auto car where the auto shifter is. Shift linkages are different so they might not fit. Again I had to do this on my 99.
You'll want to take the clutch pedal out.
I'm almost positive you'll need an automatic ECU, and since the wiring harness for the auto car has extra solenoids and such to monitor the trans, you'll have to add those in I believe for it to work properly.
I promise you, it's not worth it. And your will learn a valuable skill by learning to drive a standard and have more respect for driving and a better understanding of driving. After driving a manual, I do. And if she ever gets stuck and HAS to drive a manual for some reason, she'll know how.
Old 10-03-2010 | 07:13 PM
I agree. But I taught my oldest daughter to drive a standard....I think it took 5 years off of my life!!! Lol
Old 10-03-2010 | 07:21 PM
Here is a DIY for an auto to manual swap. No pictures, but it tells you all that gets changed. This should at least tell you what to reverse.
http://www.d-series.org/forums/trans...nual-swap.html
Old 10-03-2010 | 09:56 PM
Superfly's Avatar
It's at least worth a shot to try to teach her before you do anything
Old 10-03-2010 | 10:21 PM
DaOne's Avatar
Or find someone that wants to do a Auto to Manual swap..
and just do a full swap trade?
I know a lot of ppl want to do the swap. and it wouldnt cost you a thing in parts this way.
Old 10-03-2010 | 10:54 PM
theblackpearl's Avatar
why not just sell the car and buy an auto....
Old 10-04-2010 | 06:26 AM
I agree. I do like her knowing how to drive a standard.
From what I've been reading, there is alot of wiring issues involved too, probably not worth the hassle
Long story short...this was the other daughter's car. She ran it hot, blown head gasket, spun bearings. When I bought the car I put in an entirely new AC system, axles, brakes, etc. So after she blew it up, I pulled the D15B7 and did a D16Z6 swap. So the car is basically new (except for some cosmetic battle wounds from a teenage driver). I don't really even want to put an auto in, I just thought if it wasn't to big of a deal I would. But it looks like a pretty big ordeal, so looks like its going to stay 5spd. Which is fine with me.
