5 speed tranny interchange
Old 10-13-2012 | 06:00 AM
mycam8u2's Avatar
Default 5 speed tranny interchange
i have a 2000 civc ex 1.6 sohc vtec. i need to know what years and models will interchange with this tranny
Old 10-15-2012 | 04:44 AM
danomatic93's Avatar
June 2010 ROTM
You can use any trans from 92-00 Civic EX or lower model. I suggest trying to find one from a 96-00 EX, but one from a 92-95 EX will also be a good trans for you. All models below the EX will give you better fuel economy but the don't put down as much power.
Old 10-15-2012 | 05:46 AM
^+1
Don't use an HX transmission. It's CVT, so totally different.
Old 10-15-2012 | 06:16 AM
June 2010 ROTM
Aren't CVTs only on auto trannys? This guy needs a manual.
Old 10-15-2012 | 06:32 AM
Just making sure. In the past, someone on this forum bought the wrong transmission because we didn't specify "no HX" in our answers.
Old 10-22-2012 | 02:32 PM
mycam8u2's Avatar
ok so i got a tranny ot of a 99 civic. its all working good but the main gasket between the casing and bell housing is leaking at the bottom..how hard of a fix is this? i know there r onle like 8 or 10 bolts but does the case just slide off or will internals come apart? thanx for any feed back..its a pretty good leak
Old 10-23-2012 | 08:26 AM
June 2010 ROTM
Call me a shmuck but I had a hell of a time trying to separate the housing. I did eventually, but I wasn't trying to repair the trans, I was just trying to get some of the gears for my desk. There's a writeup somewhere in the internets on it. Search for "replace input shaft bearing civic" and see what you find.
If the trans has high miles it might be a good idea to replace the input shaft bearing if you have the housing already apart.
russell
03-06-2008 02:06 PM
batac_boy
02-07-2007 12:17 PM
benasutti
10-10-2006 10:11 AM
akidagin
08-18-2006 06:51 AM
Jetmugg
02-24-2006 08:23 AM
