5 SPEED....HERE I COME
im about to perform a tranny swap on my 98 honda civic LX, what is an average time for how long it takes to complete the swap?.....and im also wondering how much do ppl usually pay for labor?
I have the :
clutch pedal
master/slave clutch cylinder
hydraulic lines
shift linkage
flywheel
clutch kit
manual transmission
tranny mount......................................IS THERE ANYTHING ELSE I NEED B4 I GO AND HAVE IT DONE
I have the :
clutch pedal
hydraulic lines
shift linkage
flywheel
clutch kit
manual transmission
RE: 5 SPEED....HERE I COME
it will take probably a whole weekend unless you do stuff like this often, lots of work. probably and hour or 2 to get the old trans off and the same to put the 5 spd on, then do all the new part to make it a 5 spd, that is what will take forever.
well.....I have a shifter and a short shifter...so that is taken care of, but i dont have any manual flywheel bolts. does anyone know where i can get some bolts from, because i def dont see them on ebay
so your tellin me you have manual flywheel bolts for a 96-00 honda civic LX and manual ecu as well.....how much are you selling each item for???? and what is the number that i can reach you at????
