3rd gear grind?
3rd gear grind?
hey guys i think i got a problem with my tranny. when i shift at low rpms into 3rd gear its fine but once i get the revs up and switch to 3rd it has just a little grind. i just bought a rebuild kit and bushings for the shifter cause it is extremely sloppy. so could it be that? or is my tranny ****ed? and how much $ am i looking to fix it? and can i still drive it like that?
RE: 3rd gear grind?
before you go out and tear the tranny apart look into the easy stuff.....bad shifter bushings can cause it, bad motor mounts can cause it, low or bad oil can cause it. if all these fail then be prepared to have the tranny pulled apart.
RE: 3rd gear grind?
ORIGINAL: riceburner700
think your honda has bad grinds, dont ever own a dsm, you will pull your hair out with those damn trannys but man are those cars fast modified
