3rd Gear Falling Out
I drive a '99 Sedan with manual tranny. Sometimes when I'm in 3rd gear when I'm driving it will randomly pop out into neutral. It doesn't do it all the time but every once in a while. Does anyone know what might be causing this?
RE: 3rd Gear Falling Out
I found a transmission from the same car I have on ebay for $200 with about 30k on it. How hard would it be to replace? Drain the transmission fluid, remove the linkage, unscrew the mounts, then put the new one in and do the reverse?
drain fluid
eh pull axels (lower ball joint removal aint fun)
remove shift linkage
support engine (rent a hoist, its the easiest and safest way)
unplug wires
remove clutch hydrolics
unbolt trans and carfully drop down
that is the basics but buy a haynes manual its a good investment and it will have a better instructions then i can give you
unplug wires
I've got a haynes, I didn't check it for that yet though. Yeah I didn't think about the fact that part of the engine is supported by the transmission/transmission mounts. I'm guessing you also have to drain the clutch line.
honda_dud
07-10-2009 06:48 PM
