weekend project completed
Old 10-09-2006 | 09:56 PM
ef4life's Avatar
Default RE: weekend project completed
put the wider tires in the front, a front drive car would handle better that way anyway.
Old 10-09-2006 | 09:59 PM
mxs's Avatar
mxs
what size tires do you have (front and back) and what size/width/offset are your rims? and are you sure it's rubbing on the OUTSIDE?
Old 10-09-2006 | 10:06 PM
tiga10's Avatar
I haven' done it yet. its still rubbing i am going to bend up the fender wall some more. i have 205-40-17 on the fronts and back but different brand. i don't remember the brand though.
Old 10-09-2006 | 10:08 PM
tiga10's Avatar
the rims are 17x7.
Old 10-09-2006 | 10:10 PM
mxs's Avatar
mxs
alright the only way the back tire would be rubbing is if your rims are the wrong offset
Old 10-09-2006 | 10:11 PM
tiga10's Avatar
yea, i can see it on the tire. the burn makrs on the outside where the tire and fender meets. i know its not on the inside. wouln't it have made noise when i put them on a year ago?
Old 10-09-2006 | 10:16 PM
mxs's Avatar
mxs
well it wouldn't have been a problem until you lowered it.
you don't know the offset of your rims, do you??
Old 10-09-2006 | 10:23 PM
tiga10's Avatar
I can't remember it.
Old 10-09-2006 | 10:41 PM
mxs's Avatar
mxs
well . . . the overall diameter of your tire/wheel combo is barely larger than mine (by 0.19") and as far as section width your tires almost too narrow (I would have put a 215 on there) so that's not it. I have 205/45/16 on 16x6.5 w/ 45mm offset, and my car is dropped WAY more than yours. It does not rub in the back, and the fronts only rub on the inside at full lock
Old 10-09-2006 | 10:44 PM
tiga10's Avatar
i am 80% sure they where 40mm
Quick Reply: weekend project completed
