Uneven Drop
Old 02-28-2007, 03:16 PM
Infraeon's Avatar
Default RE: Uneven Drop
ORIGINAL: riceburner700
did you put the right springs on the front and the right ones on the back?
I believe so, the springs are marked w/ a model #. Two of them started with F-###, those went of the front, and the R### went on the back. Is that right?
Old 03-01-2007, 05:30 PM
gforce79's Avatar
Im having a similuar problem with my 00 civic. i bought the lowering kit from tokico. shocks and springs. the blue shocks are the hp series and it came with tokico red springs. the drop is suppose to be a 1.4 drop but my problem is that the front end of the car looks the same maybe a little higher and the back drop way more than 1.4 i can put three finger between the tire and wheel well lip in the front and only one in the back. plus i cant drive the car without the rear hitting the rear wheel well lip whenever i accelerate hard or taking a turn. i also install a camber kit on all four shocks and had the car alignment done. i have after market tires and rims on the car 17" tire size 205/40r17. i had to put back on the factory rims back on the rear so i can drive the car till i get it fix. i called tokico and the tec told me to take the camber kit off. that i dont need it with that small of a drop. is that true. any suggestion on how i can fix this problem... thanks
Old 03-02-2007, 02:01 PM
Infraeon's Avatar
Okay, I just reinstalled my springs and I did install them correctly. Afer the reinstall it sits even and there is no more shaking when I hit 70mph I guess I fudged something on the 1st install but all is good.
Old 03-05-2007, 09:10 PM
I put the EXACT same setup on my eg and a aslightly different setup on my ek (tokico hp and nuespeed springs)
my eg looked liek this with out camber kit... \\==//
my ek looked fine without camber kit and the tires wore evenly...
addiction2bass
22
06-21-2007 08:16 AM
Motor35
10-06-2006 11:13 PM
chemistry
14
07-11-2006 01:38 PM
Spartan21
12-23-2005 03:10 PM
02CivicEX
03-06-2005 10:45 AM
Quick Reply: Uneven Drop
