Tein Stech questions
#21
RE: Tein Stech questions
All right, cool. yea im only dooing a 1.5-2.0 drop so I should be fine than.. So I guess ill e getting tokico HP's and the tein S-techs. If any one has this setup please show me some pictures!!
#25
ORIGINAL: Honda_man
do you guys with the 2 inch drop have any bottoming out problems? i mean do u scrape on the ground alot?
#26
ORIGINAL: jonyg98civicex
By the way TorGa3iGhT, YOU RULE, thanks for your input on ALL my threads, you helped me to be more confident on buying the hp, tein s-tech setup. And thanks to everyone else who gave me input, you ALL RULE!!
#27
I have one more question....... IM gonna have 17's on during the summer time with low pros, will I run into any problems??
205/40/17 is the perfect fit to not have to deal with any rubbing problems. Only drawback to those tires is you will notice the ride may be a little less on the comfort side (not anything that bothers me), but it is a big difference if you are used to riding on 14" wheels.
Just keep that in mind when u buy tires for the 17" rims =)
#28
Your telling me if my camber is kinda off, I just go get an alignment and it will fix it!? Because if thats the case im not gonna spend the 300$ on a front and rear camber kit.
It'll definately save you a lot of money goin this route instead of paying for the camber kit.
#29
ORIGINAL: Honda_man
you shouldn't have a problem with scraping though. I didn't have to worry too much about scraping off driveways. if you have a body kit or lip kit, that's another story. Before adding the mugen-style front lip, i could go down most driveways fairly straight, just going slow, but once adding the lip, i realized that those driveways I'd have to go down at angles and slowly as well to avoid scraping.
but yeah, the s-techs aren't really a CRAZY drop....those have almost a 2" drop.
hope that helps!
