sway bars, tie bars, or strut bars
Old 03-16-2007 | 09:36 AM
mxs's Avatar
mxs
Default RE: sway bars, tie bars, or strut bars
ORIGINAL: jonyg98civicex
what is the benefit of having sway bars if you are just a daily driver, should i even bother buying them? or would strut bars be just fine?
they do different things. Sway bar reduces body roll. Probably a better investment. Read this: http://en.wikipedia.org/wiki/Sway_bar
And does a 99 civic si oem front strut bar fit onto a 98 civic ex?
do you recommend that type of strut bar?
yes, it works, I have one, you have to drill some holes but it's fine
Old 03-16-2007 | 03:31 PM
Stumasters's Avatar
Whats a front sway bar look like? Is it that grid looking metal underframe that looks like some sort of a underbody roll cage, or am I way off?
I think since I installed just my top strut bars I have noticed a little less "throwing" when in hard curves, in other words I don't feel like I am being slammed from side to side, but the lower bars will make a bigger effect.
For a daily driver I would think just strut bars, but if you even occasionaly go wild, do them all. I will be adding my lower setup when I get new shocks/struts. I like hair curves around 80mph with complete control.
Old 03-16-2007 | 04:49 PM
civicexracer's Avatar
ORIGINAL: Stumasters
what ur talking about is the H-brace. the bar towards the top isthe rear sway bar, the one towards the bottom with all the bends is the front sway bar.
if u want pretty good handling without the rough ride of shocks/springs, sway bars with tie/strut bars are ur best bet. u wont feel em on the straights but once u hit the turn, its def. noticable. [&:][:@]at ur last sentence...
Old 03-16-2007 | 05:25 PM
Stumasters's Avatar
lol, you don't like crazy drivers?
Old 03-16-2007 | 05:29 PM
no, im a bit crazy when on the track...i hate crazy/stupid drivers on public roads..
Old 03-16-2007 | 05:34 PM
Eun's Avatar
Eun
MY friend's trying to take off sway bar on his truck...that's a dumb thing to do right?[>:]
Old 03-16-2007 | 05:40 PM
ORIGINAL: Eun
depends...does he off road his truck? if so, its better to lose it so theres more suspension travel when going over large rocks. he'll need to be very careful when driving around on the streets tho, it'll tilt/sway alot and could easily roll if he takes a turn to fast. tell him to look into some "quick release" sway bars. i kno their popular on the Jeeps Wranglers, just snap it in place for driving around the roads, then un-do it when offroading.
Old 03-16-2007 | 09:06 PM
Kommando's Avatar
It depends on how he uses his truck and what kind of suspension he has. For offroading, disconnecting the anti-swaybar allows more articulation/flex. Some suspensions are fine without using a bar. Some vehicles sway a LOT.Quick disconnects aren't that expensive (less than $150 for the most expensive ones), and they're not even hard to fab for usuallyjust a few dollars if one has any shop skills.
Old 03-19-2007 | 02:34 AM
jonyg98civicex's Avatar
does a 99-00 civic si oemREARSWAY BARfit onto a 98 civic ex with NO modification required?
does any one have this sway bar, and does it work fine?
BB92
04-17-2008 05:56 PM
MergeThis!
03-23-2007 02:40 PM
FlipHKD720
08-12-2006 03:28 PM
speedstream
08-12-2006 11:00 AM
Savatage
06-15-2006 08:54 PM
Quick Reply: sway bars, tie bars, or strut bars
