suspension gurus?
RE: suspension gurus?
getting the old bushings out of the stock LCA's on a 5th gen is pretty easy. getting the Energy Suspension bushings into the LCA's is even easier, no need for some special hydrolic press. did my in my garage with a drill, socket, hammer,hand saw, and a vise..
well with a press its very simple to remove and instal new bushings. i had no problems doing mine. tho most people dont have presses at home to use.only took me like 2 mins to press out and in.
but as long as you block it right next to whats being pressed out you dont have to worry about that. i use 2 pieces of really thick steel thats right next to the bushing as close as posible.
o ya another tip to using a press is slap the new bushing in the freezer for awhile. it will help shrink the metal alittle and make it easier to be pressed in. i also put alittle grease in the sleeve of the pieces as well.
greasemitts
01-10-2008 06:38 PM
Patrick
22
09-13-2005 04:30 PM
