spedometer question
Old 07-05-2007 | 02:26 PM
johnb's Avatar
Default spedometer question
is it true that if you change the size of your wheels it can mess up your spedometer and give you an inaccurate reading? just curious, if so how do you fix it?
Old 07-05-2007 | 02:30 PM
mxs's Avatar
mxs
Default RE: spedometer question
it's not the size of the wheels that matters, it's the size of the tires
you avoid the problem by getting tires that have the same overall diameter as your stock tires
Old 07-05-2007 | 02:36 PM
johnb's Avatar
ok cuz my friend had stock tires and switched to low profile so is there something he should get adjusted?
Old 07-05-2007 | 02:53 PM
BlackDX's Avatar
Most of the time people will plus size their tires, meaning they will go with larger wheels and they will run tires that are as sized to keep the overal diameter the same as stock. The simpliest way to see what the numbers look like or to have your questions answered in better detail than I could muster I'd head over to TireRack. The site has the tire sizes for every vehicle OE as well as what plus size tires would be and it has explaination links all over.
Old 07-05-2007 | 02:59 PM
97Dre's Avatar
before i bought my wheels and tires, i search around alot. i found a site that u entered ur OE tire size, and u add in ur new tire size, and it gave u the diffrence in ur speedometer reading...mine..
185-65R14 to 195-55R15
it said if i was doing 60MPH on my speedometer, i was actually doing 59.9 MPH.
it does affect ur speedometer but by staying in the same OE tire diameter, u will minimize ur speedometer error.
Old 07-05-2007 | 08:11 PM
conceptualpolymer's Avatar
If you install lower-profile tires on the same wheels, your speedometer will show speeds that are higher than they actually are. As was mentioned, keep the overall diameter of your tires the same as the OEM tires, regardless of wheel size. Here's how you can calculate wheel diameter: (remember that 1 inch = 25.4 mm)
Width x Aspect Ratio = Section Height
Section Height x 2 = Combined Section Height
Combined Section Height + Wheel Diameter = Tire Diameter
Example: 185/60R14 85H or 185/60HR14
185mm x .60=111mm
111mm x 2=222mm
222mm + 355.6mm(14")= 577.6mm or 22.74"
The first number is the width of the tire in millimeters, measured from sidewall to sidewall. To convert to inches, divide by 25.4 In the example above, the width is 185mm or 7.28".
The second number is the aspect ratio. This is a ratio of sidewall height to width. In the example above, the tire is 7.28" wide, multiply that by the aspect ratio to find the height of one sidewall. In this case, 185x0.60=111mm or 7.28"x0.60=4.36".
The last number is the diameter of the wheel in inches.
To figure the outside diameter of a tire, take the sidewall height and multiply by 2,(remember that the diameter is made up of 2 sidewalls, the one above the wheel, and the one below the wheel) and add the diameter of the wheel to get your answer.
Old 07-05-2007 | 11:14 PM
johnb's Avatar
okay but say i DO change the size of the TIRE. how do i fix it in the computer so that it isnt ****ed up.
Old 07-05-2007 | 11:44 PM
I don't know of any way to do this and there's probably good reason why you can't - changing the speed calculation would allow someone to slow down the accumulated mileage (odometer). On the other hand, installing low-pro tires may increase the rate at which you accumulate miles on the odo.
Old 07-06-2007 | 12:59 AM
danomatic93's Avatar
June 2010 ROTM
Check this speedo calculator... http://www.paspeedo.com/calculator.htm
Old 07-06-2007 | 09:53 AM
johnb's Avatar
well then whats someone to do if they change the size...
