Snow Tire question
Old 11-22-2012 | 10:24 AM
Duane4238's Avatar
Default Snow Tire question
My new 2012 Civic ex coupe came with Continental p205/55r16 tires. I have a one season old set of Blizzak snows size p205/65r16 mounted on the correct rims that will fit my new Civic but I'm not sure if I can run them because of the difference in aspect ratio of the 55's vs. 65's. Does anyone know if I can safely use the snow tires? Thanks and Happy Thanksgiving everyone!!
Duane
Old 11-25-2012 | 08:47 AM
civicexracer's Avatar
The recommended tire size for your car is 205/55R16. The snow tires you have are a bit oversized. You MIGHT be able to use them, however your speedometer will be off and being a much taller tire, performance will suffer. I know they are snow tires, but snow tires already have a very soft sidewall, with an even taller tire than recommended, it wouldn't be very good. Also with it being a taller tire, you may have an issue with rubbing under hard cornering or if you are a full lock with the steering wheel.
Old 11-25-2012 | 10:16 AM
TiggerDX's Avatar
Civicexracer is correct. What I wold do is mount a set on the front and lower the car and turn the wheel completely side to side and see if they rub under full lock. If there is someone with you, have them bounce the front end while you trun the wheels to see if there is any rubbing.
If there is none or very minimal, and you are ok with it, then running them should be fine.
Depending on where you live and access to tools, you could just pit them on when there is snow on the ground and then the stock tires the rest of the time.
jj3500
12-31-2013 02:56 PM
kjsayers
06-10-2010 11:06 AM
mr_eastwood
01-24-2009 09:37 PM
sickcivic420
03-14-2005 09:15 AM
iNTRuDeR
05-15-2004 04:15 AM
