slip over coil overs
Old 06-16-2006 | 03:28 PM
thakid's Avatar
Default slip over coil overs
i got a set of Skunk 2 slip over coilovers but i am not sure how to put them on i am about to order a set of shock absorbers from inline4.com can someone tell me how to install them.
Old 06-20-2006 | 07:17 PM
thakid's Avatar
Default RE: slip over coil overs
hello
any one
Old 06-20-2006 | 08:16 PM
StifflersMom's Avatar
Cat Fuсker
they SLIP OVER your struts bro. That's it...I think there's a few rubber O-rings that go inbetween the sleeve and the strut...and that's all.
Old 06-20-2006 | 09:08 PM
Fiirkan's Avatar
Patience young padawan, responses take time, and you should pick up one of these
Old 06-20-2006 | 11:29 PM
AgentofDarkness's Avatar
Get a service manual, it tells you how to install that kind of stuff. If you have an EG civic i can even send you the service manual via a PDF file. For the slip ons, they should come with instructions and if they don't call up skunk2 and ask them where you can get instructions. For ths shock absorbers, you will have to remove the struts, compress the spring (with a spring compressor), remove the spring, install the shock, reinstall the spring, uncompress the spring, and reinstall the strut. If this is your first time doing suspension, take your time b/c suspension can be very dangerous if you don't know what you are doing. There should be a DIY on installing springs (use the search feature) and that should tell you how to remove the springs so you can install the shocks.
Old 06-21-2006 | 12:18 AM
Nail I3unny's Avatar
hey agent could you send one to me for an EG? im assuming there are going to be some things different from my old EK...
Tater
13
02-04-2007 10:42 AM
blue4door
02-01-2005 09:11 PM
grncivicvtec
01-22-2005 08:47 AM
Lab Rat 21
08-23-2004 10:37 PM
Lab Rat 21
06-18-2004 02:22 PM
Quick Reply: slip over coil overs
