Running on stilts
RE: Running on stilts
well for the most part, better handling means rougher ride. the Tokico's are stiffer than the stock suspension so it'll be a slightly rougher ride but it'll handle a bit better aswell. things u can do to make a smoother ride and get better handling: smaller/lighter/wider wheels, better tires,sway bars, and strut/tie bars.
let this be a lesson to everybody:
getting large rims and aftermarket suspension (especially coilovers) will produce a rough ride. it will never be as smooth and comfortable as your OEM setup, so choose your suspension upgrades wisely.
as for the poster of this thread, you'll eventually get used to the bumps in the road. if you want to take a bit of the edge off. downgrade to 15 inch rims and get appropriately sized tires with stiff sidewalls to maintain some degree of better handling.
ORIGINAL: civicexracer
ORIGINAL: ej6buddy
wider tread gives you a rougher ride, not a smoother ride, but it gives you a larger capacity for vertical friction due to the increased SA
o ya any larger wheel will give a ruffer ride feel...... just look at the rubber tires sidewalls... thats where ya get your comfort..... the stocker 13s or what ever have LOTS of sidewal so thiers pleanty of flex and cusion to conform to the road easier.... which should smooth over the bumps and cracks of the road......
think about it....
get a tooth brush and then a painters brush..... and pull it over a crack in the road or sidewalk the large brush brissles move alot..... more confort on the handle... now a tooth brush with the short brisles will be ruffer on the handle...
same concept... larger sidewalls are thiner and smaller sidewalls are thicker.
BUT for me.... the cosmetic looks of a 17inch rim and a good tire.... is WELL WORTH the ruffer ride.LOL
i thought about geting 16s.... BUT im gonna go back to 17s when ever i get enough cash saved up for my new rims and tires!
think about it....
i said wider wheels because u can stick a wider tire on there for better handling. a wider tire wont affect ride quality all that much if at all any..
ORIGINAL: ej6buddy
