put diffrent center caps on rims
You have to first find out the size of the bore in the center of the rim (in millimeters). The easiest way to do this is to research, or if you have hub centric rings they will sometimes say what size they are on them.
Or, you can measure yourself. You'll need an accurate measurement and every millimeter counts.
Then you take that measurement and research to find out which Honda center caps are that size.
redlines4us
01-23-2007 10:51 PM
