Is this the problem?
Old 07-09-2007 | 06:55 PM
DaRKoN's Avatar
Default RE: Is this the problem?
Its the front lower control arm. I got a new bolt put in but it only helped my problem a fraction. The wheels still tend to pull wherever they want to go. I have the feeling that some part of the linkages are loose but I dont know what. I already had an alignment and they found nothing wrong. As for the crunching noisewhen I go onthe brakes, I took of the calipers and the sliders were pretty stiff. I cleaned as best I could and then rubbed on a little grease, They slide a little better but when I push them in they still slide out very slowly. Is this normal or are they supposed to slide out immediately. I also noticed that the caliper piston seems to be rubbing an unevencircle into the back of the brake pad. I added a little grease there as well. The noise level has reduced but is still pretty loud. Any suggestions?
Slammed98silvercoupe
14
12-19-2010 05:16 PM
djt
06-21-2008 07:48 AM
redlines4us
08-22-2006 05:49 AM
tanksOnFire
01-08-2005 03:38 PM
tanksOnFire
01-08-2005 03:38 PM
Quick Reply: Is this the problem?
