OEM Rim Feedback
![Default](https://www.hondacivicforum.com/forum/images/icons/icon1.gif)
Rook here who has been lurking for quite a while, picking up knowledge...
...I've got a 96 EX Coupe with OEM 14" wheels (non-alloy) and wanted to improve the look and handling. I am not really looking for much... in fact, I'm completely satisfied with some of Honda's factory alloys. Am I safe looking at any Honda alloy with the 4x100mm lug pattern? From my research, that includes the Del Sol and a wide variety of Civic models. Are wheels from other Honda models okay to mount on Civic hubs? Are there wheel weight or balance issues I need to be aware of? Are there caliper or brake clearance issues that would keep me from moving up a size? To I need to look at toe or camber? I'll be changing tire sizes to keep overall circumference as close as possible, obviously... don't want scrubbies.
Ideally, I want to move up to 15" rims and probably no further. Again, this is just to put a little bit bigger contact patchon the ground. No, I'm not a tuner - the only other mod on this car is a K&N filter. This is a daily driver with a car seat in the back and 130K+ miles on the clock. Having done most of my mods on '70s muscle cars "back in the day," I'm just looking for a minor upgrade in the shoes. Probably the only thing the bride will let me do - good Lord, she doesn't want to lose me to the garage again...
Thanks, gents, for helping an old fart and former wrench...
Phoop out.
Phoop out.
you could get some si rims i think those are 14', but if you get some 15' they would look perfect in my opinion, it also depends on how much you want to spend on rims and tires?
ORIGINAL: Phoopster
And welcome to the forum!
Not trying to sound arrogant here, but price isn't really an object here. Since I'm not buying the bleeding edge of cool, I probably won't be shellling out terrible bones. Tires will either be Michelin or Dunlop. According to 1010's calculator, I can shoe the thing with 205/50/16 and have the identical diameter, so maybe 16 inch wheels are doable...
If the lug pattern on the stock Civ is 4x100 and the lp on the Accord are 4x114.3, does that mean the lugs themselves are 14.3mm longer? If so, Accord lugnuts would be required, yes?
Still looking for answers on wheel weight, clearance, and camber/toe issues...
Thanks!
Phoop out.
Thanks!
Phoop out.
ORIGINAL: Phoopster
clearance,
Thanks, MXS.
If 100mm is the distance between lugs center-to-center, then that narrows myc choices. Good to hear clearance is standard across the line of OEMs.
Thanks for the quick response, folks!
Phoop out.
Phoop out.
