Noise annoying help
Old 06-28-2007 | 08:01 PM
ghosttech's Avatar
Default Noise annoying help
OK well I just changed my suspension got kyb gsr-2 and its great but my back right side makes noise squeaks and stuff which is annoying I know its not my shocks does any1 know and I looked at my car and it always seem never leveled like my right front side is tilted so any1 know why also thanks for reading and helping
Old 06-30-2007 | 06:32 AM
Nail I3unny's Avatar
Default RE: Noise annoying help
Did you tighten everything back down to the right specifications?
Old 07-02-2007 | 06:28 AM
ghosttech's Avatar
Yea actually i went to a mechanic to do it but as i keep looking at it the side that makes the nosie is low could it be the spring or camber [:@]
Old 07-02-2007 | 07:42 PM
it could just be the fact that the springs are still settling. give it a couple weeks and see if it goes away.
Old 07-03-2007 | 07:02 AM
ghosttech's Avatar
ok thanks but that only happens to one side and part b/c the rest are still quiet
Old 07-06-2007 | 09:23 AM
dblclutchin's Avatar
If it starts to clunk or get wosre you might want to consider taking that rear apart again I've heard that not properly lining the spring up with the notches can cause it to clunk and make noise.
Old 07-06-2007 | 01:21 PM
ghosttech's Avatar
damn ok thanks for that i will do that this weekend then
Old 07-07-2007 | 05:01 PM
ghosttech's Avatar
question do you think is could be the tire i was reading the sizes and the one with then noise has a different size its 185/65r15 h88 the others are 195/65r15 h88
Old 07-08-2007 | 05:57 AM
SilverSedan's Avatar
that could very well have something to do with it, as well as causing some scary handling situations. For best handling have the same size on all for corners. If nothing else replace that 195 with a 185 for nothing else then proper control of your vehicle!
Old 07-08-2007 | 07:36 PM
ghosttech's Avatar
ok yea i mean i really didnt know which went best for that rim how i got it was 3 have 195 and that one that causes the problems is185 so i diff change them all so u think its best to put 185 not 195 right
Quick Reply: Noise annoying help
