in need of a lower suspension
RE: in need of a lower suspension
ORIGINAL: herbaleyes
Can the H&R not be used with stock shocks?
...I was just thinking about buying the S-Techs.... But maybe not? How are they once you upgrade to some Tokico blues or something along those lines?
blues plus H&R's would be sweet.
Camber is rotation around a horizontal axis and toe is rotation around a vertical axis.
Hm... if your wheels are leaning inwards... that's negative camber.
Try this for an explination of toe... hold your hands (your tires for this explination) out flat palms down both of them pointed straight away from you, that's when you have no toe which is about what you want for regular set ups. Now, keeping your hands flat point your fingers twards each other, that's toe in. Usually this is not good. Now, point your fingers away from each other, that's toe out. Most performance set ups will run up to .15 degrees of toe out on each wheel.
Toe is what really effects your tire wear more than most anything else. To much toe and you'll be grinding your tires off. Other things contribute though... exessive camber and tire pressure can create uneven wear.
Here, try this on for size, there's little pictures of what everything is. This is a pretty standard, slightly agressive alignment set up.
[IMG]local://upfiles/5226/CF68D96D874A4C05AE5A426510EAC70A.jpg[/IMG]
ORIGINAL: drbyers
BTW, koni shocks are expensive as hell... how you gonna get that package for under $400???
http://www.redshiftmotorsports.com/P...cial+%28Red%29
Koni Special (Red) Shocks (Applications below)
Our Price: $87.00 each
A hidden secret. These have the same mechanics as a Koni Yellow but with softer valving (softer by 35% or so) and they are only adjustable when they are off the car (in your hand). This is a very good way to get into a quality Koni shock when funds are so tight that you can't squeeze the money stone any harder. Price is 1 shock (4 per vehicle).
hmm.. well im not looking into the performance scene yet just looking to make my 18's look sweeter with a lower car. so where's a good place to get the tein s springs from..
Dcell_1t
12-20-2013 07:18 AM
brunborg
01-14-2008 08:38 AM
D16Punk
19
01-31-2007 09:45 AM
stick only
12
11-09-2004 10:12 PM
