I need some rotors
My choices:
1) PowerSlot $68.00 (Tirerack)
2) ATE PremiumOne: $52.00
3) Brembo Blanks: $40.00
If you drive over 12,000 miles a year, get the blanks, but if you keep the mileage well under that, slotted are nice because they keep the pads fresh. Stopping power is always as good as it gets with the particular pads you are using.
Brembo Blanks, or w/e decent rotor at ur local parts store. rotors are rotors, not much to them unless ur into racing. even then, many circuit racers use cheaper rotors from parts stores because they replace their brakes after every race day.
the problem i have with my current rotors is that they squeal too much. Anyways I noticed that my rotors have circular groves indented into it and the surface is not flat. Might be why its so noisy every time i brake... Do i have to change my pads as well if i change my rotors? the pads are still quite new... they're hawk hps and ive used them for only about 6 months. Will these pads cause new sets of rotors to squeal and do I need to sand down the pads or something?
lol, the reason your brakes squeal is probably because the pads are too low and need to be replaced. in the brake pads are these things called squealers that make that noise while braking when the pads are low, to let you know to change them, in case you didn't notice they were low.
