HX rims are they lighter than Civc lx rims with hubcaps
Hi guys i just bought a 99 lx civic.. When i had my HX long time ago i really liked the rims..
My question. is the stock HX rims lighter weigh that the stock rims on a LX civic? Will they bolt up?
steve
steve
yes, hx rims are 11 lbs, stock steelies are 24lbs. they have the same 4x100 pattern so they bolt right up. They cleared the calipers good on my 2000 lx, but if you dont have oem calipers, you may need to shave several .mm off, which isnt too hard.
I think you will love hx's over steelies, you will be surprised at how much less sluggish your car is, and it wont break your back every time you rotate the tires.
I found them for around $200 to around 300.. I dont need tires. Bec the car has new one on it.. I wanted to swap the tires to the HX rims.. IS there any aftermarket rims that are as light as HX rims that are around $50 wheel..
steve
steve
sorry man, i doubt you will find many if any aftermarket rims for 50 per wheel. unless you meant used per wheel. then, I'm not really sure, used wheel hunting is really luck more than anything.
If you look hard enough you could find wheels you are happy with for a couple hundred. I had to drive 2 hours both ways for the deal i found.
I was looking at new rims.. Not used.. My concern is how much they weigh.. Im going to attach the ones i found
http://www.discounttire.com/product/...fix.sm.ang.jpg $68
