How fast are my tires going to wear... or is it worth it.
Old 02-24-2007, 09:10 PM
mill$civic's Avatar
Default RE: How fast are my tires going to wear... or is it worth it.
A alignment is pretty much mandatory.
BTW, I have been driving on s-techs for almost two years now and I dont have any camber wear.With my all seasons for about a year and a half and my summers for one season. No camber wear. I should take a picture. But I DID get a alignment.
Old 02-24-2007, 10:01 PM
Belmont's Avatar
ORIGINAL: dblclutchin
Well I got my winter tires and rims on that are 15's (1.5" drop) so I should be good but I'll just have to buy it when I put my 17's on this spring. One more question, So I go and get it aligned after I install the springs and struts so when I finally put a camber kit on do i have to take it back to the shop and get it aligned again?
Lol, yea. The camber kit doesn'tadjust itself. Make sure you check your tires frequently, I had noticeable tire wear within 2 weeks.
Old 02-25-2007, 01:30 AM
mxs's Avatar
mxs
mxs is offline
you can also destroy your tires from bad toe settings; unlike camber, toe IS adjustable on older civics, don't know about your car though. I still say save the $60 to get a professional alignment.
Old 02-25-2007, 12:20 PM
dblclutchin's Avatar
^ Thanx will do
Old 02-25-2007, 12:39 PM
devney's Avatar
If you have noticably bad camber, just use the washer trick on the back. Most likely your camber isn't going to be badthough with s-techs.
remy
08-15-2008 08:13 AM
97Dre
08-13-2007 06:42 PM
Powermidget
ED-EF Swaps
02-08-2007 11:34 AM
kikaSI
11-13-2006 11:52 PM
the_reptilian
01-16-2005 05:15 PM
Quick Reply: How fast are my tires going to wear... or is it worth it.
