Helpwith lowering please
Old 11-24-2007 | 09:06 AM
Hotsawce97's Avatar
Default Helpwith lowering please
Hey guys, I have a 97 honda civic with 17" rims and tires. I was wondering if i get 3" lowering springs on the back, and 3.25" on the front would they rub on my tires? If anyone know if they would rub on my tires could you please let me know? thanks
Old 11-24-2007 | 10:29 AM
mill$civic's Avatar
Default RE: Helpwith lowering please
Im pretty sure they would man. I had 17" wheels with 205/40 on my car with about a 1.8 drop all around. Mine would never rub, but it would hit my fender if I go over a big bump or somthing and my wheels are turned. A 3 inch drop is pretty big..
Old 11-24-2007 | 10:48 AM
Hotsawce97's Avatar
You think 2.50 front and 2.25 back would be to much?
Old 11-24-2007 | 05:33 PM
Civic Dx 349's Avatar
Member
Just get a set of coil overs instead of lowering springs and you will be better off and happier in the long run. Slam your car in the spring/summer and lift it back to stock for winter unless your like me and have a summer civic and winter civic.
Old 11-24-2007 | 08:58 PM
Offset has a lot to do with whether or not the wheels will rub. I believe you need at least a +40mm offset (I think) for the tires to tuck properly (that is, of course, assuming you have the correctly sized 205/40 tires). Trust me, you'll be tucking tires with a 3"/3.5" drop (and even a little in front with a 2.5" drop). I'd say get coilovers, especially given that most lowering springs won't lower much over 2" (the keyword being "most".). Ground Controls are extremely popular, and for good reason. I have them and absolutely love them. Just remember that you have to get the alignment checked and corrected every time you play with the ride height.
Old 12-15-2007 | 11:33 AM
Mylittlecivic's Avatar
I got 215/50/17's with a 1.75" drop with H&R springs. THey only rub if I hit a huge bump or somthing so im putting coil stabilizer mounts in this weekend.
hope it helps
I would suggest 45's for tire size
illFactor
04-13-2011 03:23 PM
CrIyVaInC
11-22-2007 11:51 AM
addiction2bass
01-27-2007 07:27 PM
cornerblitz59
07-25-2006 09:26 PM
Honda99Civic
04-20-2006 11:13 PM
