Front Brake Pads (Again!!!)
I have an '01 Civic EX with ABS. Only 39K miles and I'm starting to get some squealing noise from the front end. Sounds like worn pads rubbing on the rotor. Do the pads wear out that fast?
In any case, I'd like to check the pads and see how worn they are. I have a one-car garage so my space is limited. I reckon I'll pick up a couple of jack stands. Is there an obvious place on the transaxle to put these?
I've done a search and found a bunch of posts about changing the pads. I do have a question, though. Someone said to remove the bottom bolt on the caliper to remove it and someone else posted that when he did that brake fluid leaked out. I'm assuming there are top and bottom bolts.
Any help and advice would be greatly appreciated. I'm not a mechanic by any means but can do all kinds of work on my motorcycle. Cars are another story, though! [sm=smiley2.gif]
Thanks!!
Barry
Thanks!!
Barry
RE: Front Brake Pads (Again!!!)
You need to remove the lower bolt for the caliper then the caliper will flip up so you can look at the pads. As far as jack stands go, if you look by the front doors under the car you will see 2 pieces of metal that are part of the frame. This is where you want to place the jack stands. If you look at the front of the car behind the bumper there is a piece of metal, you can put a jack under there and lift both sides of the car at the same time.
wil
01-18-2013 04:27 AM
j2performance
01-25-2008 09:40 AM
j2performance
01-15-2008 01:48 PM
csapp05
02-24-2007 01:16 AM
