DIY Shocks/Springs (rear) install
Old 06-02-2006 | 08:33 PM
sacicons's Avatar
Default RE: DIY Shocks/Springs (rear) install
nice writeup. Ill have a few pics of an install on mine soon too, but I suggest before you lift the car, you take the nut off of the top of the shock, then when you lift the car, the springs are already loose, so it saves you from messing with the compressor at least once.
Old 06-02-2006 | 10:59 PM
Pete's Avatar
Nice writeup sniper. I will hopefully be getting a new suspension setup soon........I gotta get the 5 speed swap done first though.
Old 06-10-2006 | 12:23 AM
mxs's Avatar
mxs
here's a question: if I were only changing the springs, and reusing the stock shocks, would I need to detach the shock from the lower control arm? or just detach it from the upper mounting point?
forty, since you're here, what was the bolt/bushing that gave you trouble?
Old 06-10-2006 | 04:46 PM
AgentofDarkness's Avatar
You will have to take the strut out to install a new spring. If you detach it from the upper mount, how will you get the spring out? You prolly will not have enough clearance between the strut and the upper strut tower. Even the spring compressed is pretty big. It will be shorter, but its diameter will still be the same. I've also never heard of anyone changing the spring w/o removing the strut.
Old 06-10-2006 | 07:14 PM
mxs's Avatar
mxs
ORIGINAL: AgentofDarkness
ok, well I've never taken my suspension apart, that is why I was asking
Old 06-11-2006 | 12:09 AM
I wasn't trying to flame or anything, jus pointing out why it wouldn't work.
Old 06-12-2006 | 08:56 AM
ORIGINAL: mxs
It was the Drivers side Rear LCA bolt/bushing. The one that holds the shock to the LCA. PB Blaster and an impact gun probably would have helped.
Old 06-24-2006 | 12:53 AM
awsmp5's Avatar
sweet, i'll be gettin my HP's in real soon and civicexracer up there'll be isntalling the same exact set up! damn can't wait
where'd you order yours from?
Old 06-24-2006 | 10:13 AM
Savatage's Avatar
Hey Sniper, when are you going to do the front?
ajfd90
09-05-2007 11:05 AM
spintelect
05-17-2007 04:23 PM
mxs
Suspension & Steering DIYs
06-12-2006 09:46 PM
mill$civic
05-02-2005 11:36 PM
Civic Mania 160
12-08-2004 11:02 PM
Quick Reply: DIY Shocks/Springs (rear) install
