Custom Spring Rates
Old 01-15-2007 | 02:35 PM
Kedawei's Avatar
Default Custom Spring Rates
To the suspension gurus we have on here, are there any links you have to help one determinethe proper spring rates to use? A calculator of sorts?
Or perhaps, how would you/did you determine the spring rate you use on your set up?
Old 01-15-2007 | 02:54 PM
mxs's Avatar
mxs
Default RE: Custom Spring Rates
it depends on what you want to get out of the car (comfort or handling) as well as which shocks you are using. the shocks need to provide proper damping for the springs you choose. here are some links to get you started
http://www.wtrscca.org/tech.htm (general)
http://www.se-r.net/car_info/suspension_tuning.html (Sentra specific but the chart in the middle of the page is still pretty relevant)
Old 01-15-2007 | 03:13 PM
Kedawei's Avatar
I know most of the general principles from the Gran Turismo games. But I will read through both articles when time permits and try to further refine my question.
Just fyi in case you might have a suggestion, the car in question is an old CRX weighing about 1700 pounds, making about 150whp, and will be set up soley for road racing.
SupermansDX
11-22-2009 12:00 AM
Lost
03-17-2008 09:04 PM
Fiirkan
11-13-2007 06:05 PM
red2000Si
01-19-2007 02:53 PM
H22CIV
11-30-2006 04:07 PM
