Brake bleeding/pressure problem
Hey guys,
So as you know on my ef I swapped the brakes all the way around from a da9. Also the master cylinder, brake booster and 4040 valve. So my problem is when I go to bleed the brakes tons of air comes out and some old fluid but the fluid in the master cylinder does not go down and no brake pressure is gained. I worked on bleeding the brakes for about and hour straight, I have a good one man bleeder kit. So when I go into the car and press the pedal it goes to the floor. I'm thinking bad master cylinder. What do you think? All help is greatly appreciated!
So do you think there's a problem with the bleeder tool or how you are using it?
