Best tire size for my application..
Hey guys, I got a 98 dx. I'm going to be installing skunk2 lowering springs which gives a 2.25" drop. I just bought some nice used wheels that are 16x7 with a +38mm offset. I dont want rubbing problems but with that offset im not sure if i can avoid it. The tire size i was thinking is 205/40-16. Any opinions on this guys?
I have front and rear camber kits to go in with the springs and shocks. When I get it aligned could I just tell the guy to set some negative camber? I've heard mixed opinions on negative camber affecting tire wear..Im not sure what i should do?
Everyone I know with S-Techs ended up at about a 2 inch drop and the back looking slightly lower than the front, hardly noticeable unless you look for it.
I am running 205/40/16 tires with a +40 offset lowered on Neuspeed Race springs rated at 2.25 front and 2 rear drop. Not even close to rubbing.
96-00 Coupe/sedan 205/45/16, 96-00 hatch 205/40/16
