235/50/16
Old 08-13-2006 | 10:04 PM
koonce727r's Avatar
Default 235/50/16
was wondering if anyone knew if a 235/50/16 would rub on my 06 ex, or do you think i will be alright
Old 08-13-2006 | 11:51 PM
Nail I3unny's Avatar
Default RE: 235/50/16
what size are the wheels? that seems awfully wide to me...
Old 08-14-2006 | 10:48 AM
KarTuneMan's Avatar
So it sounds like you just want to put a bigger tire on your stock wheel....correct?
If so....it's not gonna work... For 2 reasons, first, the stock wheel is not wide enough to accommodate 235mm's of tire. Secondly, it's too tall, almost an inch.
Now, if your gonna replace tires AND wheels...consider a 7.5 wide, and maybe a 225, instead of a 235.
Old 08-15-2006 | 12:56 AM
koonce727r's Avatar
do u think the 225 would be to wide for the stock wheel???
Old 08-15-2006 | 02:49 AM
KarTuneMan's Avatar
The best tire size for the stock wheel, is the size thats on the car..........
Old 08-15-2006 | 03:10 AM
Marty's Avatar
Best is such a brod term, the stock size tire is the best for ride quality and lack of road/tire noise but I can name a couple reasons a different tire size is needed. Also you would be hard pressed to fit a 235 tire under a civic, actually you are pushing it at 225
Old 08-15-2006 | 10:38 AM
koonce727r's Avatar
Maybe ill just sell them and get some new 16s
Old 08-15-2006 | 11:12 AM
koonce727r's Avatar
so would a 225 fit on my stock 16s?
Old 08-16-2006 | 11:46 AM
KarTuneMan's Avatar
They are quite wide, the tire will have that "pinched" look, and the sidewalls will be rolled, rounded, instead of flat. If you have to have a wider tire....get new wheels.
Old 10-31-2006 | 09:03 AM
Sleepin95CivicDX's Avatar
bringing this thread from the dead, i have aftermarket 16x7 wheels on my 95 coupe, and with traction problems from the turbo, im looking to go bigger tires too. since a 7" wheel can fit a 225 width tire, do u think id have problems rubbing? looking at 225/50/16's on the front, and keeping my 205/40/16 on the back. thanks!
btw, its stock ride heigh, no lowering
