twincharger question
i have a fully built d16z6, no turbo yet as im still deciding on the size i want. another problem i have is i want it super and turbo charged. so i need to know what to do to the turbo so it can handle the higher flow from the supercharger. if i get a bigger turbo with more lag that kicks in at higher rpms, and get a twinscrew supercharger that works at lower rpms im pretty sure it would work. i just don't want to buy both and blow my turbo. so if anyone knows what i need to do please let me know.
thanks for the info in advance. and ps money is not an issue so any combo of turbo/supercharger you think would work the best let me know.
I'd say just get a nice turbo set up, good tune and call it a day.
Any turbo will fit on any engine. What you need to fit the engine would be the turbo manifold. Luckily, the factory exhaust manifold from a CRX HF will bolt directly up to a D16Z6 and you can weld (or have welded) any turbo flange you want on it; a lot of people with "home-made" turbo setups are running modified HF manifolds, and the best part is they're not that hard to find for a good price on eBay. The HF manifold is a "log" style manifold so it's not the best in the world for flow, but unless you're making crazy amounts of power it will be non-issue.
If you really want as little lag as possible and have the money for one, look into variable-vane turbos.
And yes, you can run nitrous with any method of forced induction (or natural aspiration) you want. Just keep in mind that your engine will need properly set up and tuned for nitrous; unfortunately, I know next to nothing about N2O setups, so hopefully someone else can chime in.
yes it will be a weekend race car only. i don't want that much power for daily driving. the turbo i want is - 63mm Garrett GT40R GT4088R GT4088 Dual Ball Bearing Turbo - is this to big? or could i go bigger? input please
