Which turbo would be best for a B16?
RE: What tubo?
still a bad idea. its vertical pressure on the rods that makes it worse for boost when stroking.
if you wanted to stroke it you should bore it too. the biggest stroker kit that Crower carries for the B16 looks ok for boost...87x89...but i still think that altering the dimensions in a b16 is not a good idea.
RE: What tubo?
if you peice the turbo together yourself you will have more money for the engine itself.
HKS manifold flanged for Tial 44mm wastegate, Tial 44mm wastegate, Garrett T3/T4 turbo, 3" downpipe, custom mandrel piping, Spearco intercooler, GReddy or HKS BOV. that should set you up for up to 25psi on about a grand.
