Turbo on Road Trip
Old 03-30-2006, 12:44 AM
AgentofDarkness's Avatar
Default RE: Turbo on Road Trip
Couldn't you get a boost controller and turn the boost way down?
  #22
Old 03-30-2006, 01:07 AM
no you can only turn boost up. The lowest setting is set by your wastegate spring and then you "hide" boost from it to make it go up.
Berz out.
  #23
Old 03-31-2006, 05:58 PM
D16z6's Avatar
So whats a good turbo that give civic the most whp per lbs?
  #24
Old 03-31-2006, 07:39 PM
Full-Race (www.full-race.com) makes some good turbos, or so i hear. There is a turbo that makes 450HP on a stock motor and retains A/C. Its for a B series engine, but its still pretty impressive. I know that Full-Race has a D series with almost 800 HP on thier website. Its definatly not stock, but its still lots of power. I would check around on thier site, but i think you have to call them up for D series engines.
  #25
Old 03-31-2006, 08:50 PM
Kedawei's Avatar
ORIGINAL: AgentofDarkness
They have a B approaching 800, I think, but not a D. I don't know that a D could make 800, even on methanol.
  #26
Old 03-31-2006, 09:36 PM
Pink SOHC Civic Story. If you goto towards the bottom of the page, it shows a dyno sheet and they write that 790.1 WHP and 610 ft/lbs of torque. I think the 790 number is off the pink SOHC but i could be wrong.
  #27
Old 03-31-2006, 09:51 PM
Kedawei's Avatar
Yeah, that's this motor: http://forums.evans-tuning.com/viewt...ighlight=gt40r
Bored B18.
  #28
Old 04-01-2006, 06:15 PM
D16z6's Avatar
Im talking about whats a good turbo size the give the most whp per lbs. Also is liquid intercooler any good?
  #29
Old 04-01-2006, 07:22 PM
I think that the air to liquid IC are the best, but they are also the most expensive. You need alot more stuff for that, its liek another cooling system. Most people have Air to Air.
  #30
Old 04-04-2006, 04:02 PM
Yeah i agree with most of the posts, i never even hit boost on the highway and i can go about 80mph. Like someone else said unless ur a bat out of hell shifting (haha that made me laugh so hard) it shouldnt be a problem. I wouldnt even keep it at 1lb whats that point? might as well be safe and not even tempt yourself.
Quick Reply: Turbo on Road Trip
